Announcements
Saving Workspace
ubiratanRE79B
Saving Workspace
ubiratanRE79B
I am not sure if this feature is already implemented in Fusion 360 because I could not find anything about that. If not I suggest to include an automatic function to save the workspace as it was adjusted in the last use. Today I have to adjust the width of all internal windows every time I open a project. It would be a time saving function.
Thank you !
jorge_garcia
Hi @ubiratanRE79B,
I hope you're doing well. The panels positions are supposed to be remembered along with their size, the latest release of Fusion has some improvements in this regard.
What specific windows are you having to resize?
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
ubiratanRE79B
Hi Jorge,
today it happened in the schematic window where we can see the sheets. The height was too high, different than the adjustment I made last time I opened one schematic. That happens all the times I start Fusion. It does not matter if I open a board or an schematic.
Thank you.
ubiratanRE79B
Hi Jorge.
The issue is still happening. Every time I open a project the Inspector and sheets panels return to the same position that is different than the ones I adjusted before closing Fusion. It is annoying.
Any solution for that ?
Thank you.
Ubiratan
ubiratanRE79B
Jorge,
I just made a test opening Fusion design examples and after that one of my designs. When I work with the examples the panels dimensions are saved and recovered when I reopen the project.
But when I am working with my designs the panels dimensions are not saved. Maybe this information could help your team.
Thank you.
Ubiratan
jorge_garcia
Hello @ubiratanRE79B,
I hope you're doing well. I'll report this back to our developers.
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
