Fusion Electronics
Working an electronics project and need help with the schematic, the PCB, or making your components? Join the discussion as our community of electronic design specialists and industry experts provide you their insight and best practices.
Routes blocking move on PCB board
3 REPLIES 3
infoAGJ6T
514 Views, 3 Replies
Hi all,
I routed my board and then needed to replace a part in the schematic. Now I can't move it on the board because it seems the routes are blocking it. I tried the different move modes (free/disconnect) but that didn't help. What am I doing wrong?
https://youtu.be/QERTIGv8NOo
Labels (1)
3 REPLIES 3
Your part is being blocked by the other parts because of the "Push Violators" mode being enabled now. As it looks like you want to move your part to the inside, you could temporarily turn on "ignore obstacles" in the menu to overcome this:
Pieter-Jan Van de Maele
Senior Engineering Manager, Fusion Electronics
Thank you, that worked! I never knew about that option.
It was only added since the last update in August. Push/Shove & Obstacle Avoidance got expanded to every edit operation rather than just Route. This is why that option was moved to the editor-level.
