rough surface but only on one side
david_w_faulkner15
david_w_faulkner15
Using the loft tool I created a box with a smooth transition between its' sloping sides and the base
but
when printed the surface finish on two sides is awful, the other sides are perfect
In the example shown the surface with the LED's is poor, the one with the USB socket is good
I did not use any supports as the angles arent that steep and am printing in PETG @ 0.12mm layers on a new Bambu A1, the "good" sides are super smooth and very even
Other projects are super smooth all round
Any ideas please
Replies (15)
jeff_strater
I don't think that this is a Fusion modeling problem.  The geometry here looks fine on both sides.  I show Gaussian Curvature and Zebra Stripe analysis:
Screenshot 2025-01-01 at 6.50.07 PM.pngScreenshot 2025-01-01 at 6.49.57 PM.pngScreenshot 2025-01-01 at 6.49.23 PM.pngScreenshot 2025-01-01 at 6.49.14 PM.png
So, I suspect that the problem is with your printer, or the slicer, or the software driving the printer, but I think the model is fine.
Jeff Strater
Engineering Director
david_w_faulkner15
OK, thanks
It is strange that the other sides and also the vertical part above the slope all printed perfectly.....
david_w_faulkner15
I tried printing it with and without supports but the result was exactly the same
The INSIDE printed perfectly smoothly, the outside was very rough and poor
It APPEARS to be the result of the “loft” function which created the sloping sides but we cannot see why
Have attached the test piece for other suggestions
Thank you
david_w_faulkner15
additional pics
jeff_strater
Not sure.  I suspect it is the holes more than the loft, but I have no proof of that.  All the 3D printer sees is triangles.  It cannot "know" that those triangles came from a loft.  I did notice that the STL you shared had a wide variation in triangle sizes on that face.  Perhaps that is confusing the slicer.  You could try exporting as mesh, and manually try to adjust the mesh so that it is more uniform, and see if that helps.
But, I really wonder whether this is a 3D printer setting/calibration issue more than anything.
Jeff Strater
david_w_faulkner15
Thank you for your prompt reply.....
Strangely I have found that using higher layer sizes the problem is reduced
>From the left :   0.16, 0.12, 0.12, 0.08
david_w_faulkner15
Hazah.... we (my son is the brains 😁) applied the create mesh as you suggested and the result is superb and fully acceptable
thank you
attached examples printed @ 0.12
david_w_faulkner15
are there any hard and fast rules or guidance as to when we should use  mesh rather than the default export .....would it be better to always use mesh if there are any complex curves etc?????
vilenpro
Observer
Observer
I have the same behavior on a model that i used "loft" to cut a "double" slope. When looking in the slicer (Orca) it seems the inner walls are visible on this slope which makes the surface rough.  If i cut the slope using "extrude" feature these the inner walls are not visible. Same project, same Orca settings. I guess the issue is in the "loft" feature.
We cured the problem by exporting as "grid"......it then printed perfectly smooth
I can't find this format in the export options. Is this an option in Fusion that needs to be turned on? Google doesn't give me too much information about it.
david_w_faulkner15
Go to mesh tab > create > tesselate.
Click the body(s) you wish to export, these will be what gets turned into a mesh.
Lowering Surface Deviation and Normal Deviation makes the resulting mesh more accurate, with more triangles.
Click OK to create the mesh, it may take a few seconds to process. You should then see a mesh appear:
Before you export, make sure to hide the original bodies and only have the mesh(es) shown:
Then export as usual in whatever format you usually use (e.g. .3mf)
The high detail mesh will be what gets exported.
Thank you so much for a such detailed instruction. I'll give a try.
All credit to my son....its way beyond me
All credit to my son....its way beyond me 😁
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
