Fusion Electronics
Working an electronics project and need help with the schematic, the PCB, or making your components? Join the discussion as our community of electronic design specialists and industry experts provide you their insight and best practices.
Rotate Groups of Wires
2 REPLIES 2
jss.mlls
132 Views, 2 Replies
I have these coils of wires in my PCB:
I would like to rotate these wires about the center of the circular cutout (ideally keeping their net names). Any ideas on how I can do this? The simple rotation command does not work.
Jesse
2 REPLIES 2
jorge_garcia2
in reply to: jss.mlls
Hi @jss.mlls,
I hope you're doing well. You want to do a group rotate to achieve what you want. Here's the procedure.
1) Make a selection that contains all of the coils
2) Activate the rotate command
3) Hold ctrl and then right-click on the point you want to be the axis of rotation.
Voila! If you want to be specific about the axis of rotation then after step 2 you  can type the specific point in the CLI with the following syntax. (> x-coord y-coord) press enter.
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
jss.mlls
in reply to: jorge_garcia2
Thanks Jorge, that worked great.
