Fusion Electronics
Working an electronics project and need help with the schematic, the PCB, or making your components? Join the discussion as our community of electronic design specialists and industry experts provide you their insight and best practices.
Rotate Designators on Board 180 degrees
4 REPLIES 4
kterryTYYYC
186 Views, 4 Replies
I cannot figure out how to rotate footprint names (part designators) 180 degrees on the board silkscreen. I do not see a "spin" option like on stand-alone text placements. Thanks!
4 REPLIES 4
jorge_garcia2
in reply to: kterryTYYYC
Hi @kterryTYYYC,
I hope you're doing well. Thanks for coming on to the forums!
So you could do this by selecting all of the designators and then using the rotate option in the inspector. Another option is to use the Autoposition attributes command to orient all of the designators a certain way.
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
kterryTYYYC
Hi Jorge, thanks for your reply. Unfortunately rotate and reposition attributes automatically re-orients the designators to 0 degrees or 90 degrees. It will not let me flip them to 180 or 270 (see picture). Thanks!
jorge_garcia2
Hi @kterryTYYYC ,
I hope this message finds you well. My mistake, you'll find that the spin flag is part of the rotate command. So activate the rotate command and you'll see the option to control spin there.
Best Regards,
Jorge Garcia
kterryTYYYC
Ahhh, finally! Thank you! That was unnecessarily painful. Part of the learning curve I guess. Thanks again.
