Fusion Electronics
Working an electronics project and need help with the schematic, the PCB, or making your components? Join the discussion as our community of electronic design specialists and industry experts provide you their insight and best practices.
Replace component and resolve pin differences
3 REPLIES 3
josh_l
89 Views, 3 Replies
I often want to replace one component in a schematic with another, but unless it's something highly standardised like a resistor or capacitor, it usually doesn't work because of pin naming differences.
Here's an example of what happens when I attempt to replace a memory chip with a different chip that is pin-to-pin compatible but has slightly different pin names at the library level:
Is there a way to instruct Fusion Electronics how to resolve these differences during the Replace process? I know that Fusion has this ability when resolving Net name overlaps when importing one design into another - I am looking for something akin to that for replacing components. Does this exist?
Josh
Tags (1)
3 REPLIES 3
jorge_garcia2
in reply to: josh_l
Hi @josh_l ,
I hope you're doing well.  From the documentation here is what is required for REPLACE to work:
"The old and new device must be compatible, which means that their used gates and connected pins/pads must match, either by their names or their coordinates. "
If you don't have a match then you basically have to delete the part and re-insert it.
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
josh_l
in reply to: jorge_garcia2
Thanks @jorge_garcia2 for the reply.
 It would be great if Fusion had a popup window with options to resolve the issue, rather than just a message that says it can’t be done. A column on the left for the original part’s pins, and a column on the right for the replacement part’s pins, like the window where you connect the pins for a Component in an electronics library. It feels a bit thin to be undone by identical parts with identical pin numbers but slightly different names. Even a “Would you like to replace the pins 1:1 by pin number” would solve it most of the time, especially when replacing connectors which I often find myself doing.
Cheers,
Josh
jorge_garcia2
in reply to: josh_l
Hi @josh_l ,
I hope you're doing well.  That's a good suggestion I'll push this up the chain for future improvements of the replace command.
Best Regards,
Jorge Garcia
