Fusion Electronics
Working an electronics project and need help with the schematic, the PCB, or making your components? Join the discussion as our community of electronic design specialists and industry experts provide you their insight and best practices.
Removing solder mask for heat dissipation
3 REPLIES 3
yamamoto.mas
530 Views, 3 Replies
As U201 is a motor driver, I would like to remove solder mask at the chip bottom for better heat dissipation.
What is the best way to do it ?
3 REPLIES 3
panpan_fan
in reply to: yamamoto.mas
Hi @yamamoto.mas
I hope you are doing well!
You can try the following steps :
1. Switch layer to 30 bStop
2. Draw Rectangle on the 30bStop
3.Push to 3D PCB -> Check Stop Layer Geometry -> OK
4. Check 3D PCB, the solder mask will be removed
Please have a try, thanks!
Panpan Fan
yamamoto.mas
in reply to: panpan_fan
Thanks for help.
It works !!!
panpan_fan
Good to know it can help!
Panpan Fan
