Fusion Electronics
Working an electronics project and need help with the schematic, the PCB, or making your components? Join the discussion as our community of electronic design specialists and industry experts provide you their insight and best practices.
Removing linked PCB that isn't available?
2 REPLIES 2
roman.snajdrGXU9X
132 Views, 2 Replies
Lately we're experiencing some issues pushing PCBs from Eagle to Fusion and get "Error pushing to fusion" and blank error reports all the time. This led to a PCB that was put into an assembly (linked) being unavailable. Since I'm using the timeline I'll have to unlink this PCB before using "remove" and can't use "delete". But since I can't update the PCB because "Design data is not available for the document" it fails at unlinking it... Has anyone else experienced this viscious circle and found a solution?
Thank you!
Roman
2 REPLIES 2
This relates to Problem pushing PCB to Fusion: File type changes after a while - Autodesk Community - EAGLE which deals with the PCB becoming unavailable
Cheers
Roman
Anyone?
