Fusion Electronics
Working an electronics project and need help with the schematic, the PCB, or making your components? Join the discussion as our community of electronic design specialists and industry experts provide you their insight and best practices.
Remove unwanted and unnecessary airwire
1 REPLY 1
infinite.machinery
600 Views, 1 Reply
I'm working on a two PCB product that used standard 2.54mm pin and socket connectors to bind the boards together. There are two sets of pin/socket combinations connecting the boards. On each connector set I have a pin that is externally connected to +12V. I want to have the net name for the pins to be +12V but not have an airwire between the two, since they would not be directly connected to each other.
Is there a way to disable the airwire between the pins, or is it just a simpler solution to give the pins different net names?
1 REPLY 1
Hi @infinite.machinery,
I hope you're doing well. If they shouldn't connect then I would say to give them different net names. Keeping them the same is only going to create confusion down the road.
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
