Fusion Electronics
Working an electronics project and need help with the schematic, the PCB, or making your components? Join the discussion as our community of electronic design specialists and industry experts provide you their insight and best practices.
Remove component information
1 REPLY 1
wisse.pielage
472 Views, 1 Reply
I have a pcb from eagle with all the 3d components. Every component has its devicename in the assembly.
Is it possible to remove this information and save the assembly as a part (so someone else can not view the components or move them)?
Thanks in advance
1 REPLY 1
Hi @wisse.pielage,
You need to (in Design workspace, not PCB), select Modify->Combine
And combine all physical bodies into 1 body
This will mean 1 component, 1 body
Then you can delete all the empty component hiearchy
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
