Fusion Electronics
Working an electronics project and need help with the schematic, the PCB, or making your components? Join the discussion as our community of electronic design specialists and industry experts provide you their insight and best practices.
Random crashes since last update
8 REPLIES 8
Message 1 of 9
rbkyorem
302 Views, 8 Replies
I have been getting random crashes on Fusion 360 with the latest update. I have been using electronics and I don't know if it would also happen on 3D sketches.
Crashes does not happen periodically. They  happen even after 1 min or after 10 min while I am editing text or moving components etc .
I do not believe it is related to my PC. It happens both on my laptop and desktop.
I am here asking if it happens to anyone else here too?
LAPTOP: I5 9th, GTX 1650, 16GB DDR4, SSD.
DESKTOP: I7 12700K, 32GB DDR5, RTX4080, NVM SSD.
8 REPLIES 8
Message 2 of 9
rbkyorem
in reply to: rbkyorem
I had more than 5 crash in last 1 hour...
Message 3 of 9
@rbkyorem Have you been submitting the crashes to us? Can you provide a report ID if you are submitting them?
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
Message 4 of 9
It becomes non-responsive I can not get any report.
Message 5 of 9
@rbkyorem @We certainly are not hearing problems of this nature.
would help to do and check on a couple of things.
1. Any pending windows update ?
2. check to see if there are any graphics update ?
3. Go to add/remove programs. Select Fusion 360. Modify - this will launch the Fusion 360 service utility. Run a repair Fusion from here.
Now login and try again. .
Autodesk Fusion
Join Fusion Insider
Message 6 of 9
708826075
I think this crash was unrelated with other ones but here is a report number.
I do have some pending updates but my drivers are up to date not years old.
Message 7 of 9
@rbkyorem Can you update Windows and also run the repair Fusion 360 that I called out above?
Autodesk Fusion
Join Fusion Insider
Message 8 of 9
I have updated windows and my graphic card driver. I can run long sessions on Fusion 360 now. I haven't tried repair Fusion 360 step.
Still getting that crash rarely when I try to update a component by readding it.
Thanks for for the help.
Message 9 of 9
@rbkyorem @Please send in the crash report and we can take a look.
Autodesk Fusion
Join Fusion Insider
