Fusion Electronics
Working an electronics project and need help with the schematic, the PCB, or making your components? Join the discussion as our community of electronic design specialists and industry experts provide you their insight and best practices.
"Write DBL" is not writing out a file
1 REPLY 1
chris_cummingsDT
62 Views, 1 Reply
We have been saving out Design Blocks in Fusion 360 for several months. It is a very important part of making LED strips. We tried yesterday and it tries but writes a Zero Byte file that shows up in Recents in Windows, but does not really exist in the folder.
1 REPLY 1
"Write DBL" has been deprecated in favor of the wonderful new "Insert Electronic Design" Under the Place dropdown on the ribbon. Do it in the schematic and the board file will behave just like it was a design block (layout preserved).
If we can ever get this to be linked, then changing the inserted Design file will make it behave like a library object, and will update the designs it is inserted into.
