"Change" tool dropdown getting cut off
n.smithHJCP5
n.smithHJCP5
There's an odd bug with the "Change" tool (wrench icon). When I scroll over the drop down for an option, the last option is cut off.
However, if I were to hover over "Diameter" and then go back to hovering over "Display" the error goes away.
This is a larger issue for options with customizable fields. The "..." gets cut off so there's no way to enter a custom, for example, Drill size without discovering this workaround.
I do run into issues with screen resolution now and again (plugging and unplugging laptop to external monitor) messing with aspect ratios and text size but this doesn't seem to be directly related to that.
Fusion 2.0.18961 x86_64
panpan_fan
Hi @n.smithHJCP5
I hope you are doing well!
Today we release Fusion V2.0.20256 and this issue should be fixed.
Please upgrade Fusion and have a try, thanks a lot!
Panpan Fan
