Fusion Electronics
Working an electronics project and need help with the schematic, the PCB, or making your components? Join the discussion as our community of electronic design specialists and industry experts provide you their insight and best practices.
Quickly select layer set
3 REPLIES 3
infinite.machinery
270 Views, 3 Replies
Eagle has a way to quickly a layer set without having to bring up the layer modal dialog. That ability seems to be missing from Fusion 360. Is there a way to do this in Fusion 360?
3 REPLIES 3
Hi @infinite.machinery,
I hope you're doing well. Are you referring to a shortcut, or using some sort of ULP?
The shortcut route probably won't work right now since they are not user adjustable, but the ULP route will still work. The display command still supports that layer presets so I know you can use them that way.
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
I don't quite understand your answer. Why is it that Fusion 360 does not have this quick selection list of layer sets like Eagle does? I have to bring up the modal layer dialog box in order to select a layer set.
I hope you're doing well. This functionality hasn't made it into Fusion360 Electronics yet. Thanks for the picture it really clarified what you were asking. EAGLE has several ways to for calling layer presets that's why I responded the way I did.
Best Regards,
Jorge Garcia
