Fusion Electronics
Working an electronics project and need help with the schematic, the PCB, or making your components? Join the discussion as our community of electronic design specialists and industry experts provide you their insight and best practices.
Problems with push to 3D
7 REPLIES 7
Message 1 of 8
mario.brizida
167 Views, 7 Replies
I still have problems with push to 3D that I don't understand, and now I'm sure that I did nothing wrong:
I have this simple pcb design:
that gives this image on manufacuring preview:
Correct
I have below stack definition:
and I get this 3d pcb!!!!!
Be sure that all layers on 3d are on:
But nothing appears!
If I remove 3d pcb link, and generate another 3d, I get almost the correct image:
but with A LOT of errors. And I don't have the holes placed (they get an error).
If I press again 3D pcb it wil generate first image of this post:
Fusion team: please understand that our job doesn't complain with this kind of errors. You must understand what is happening and urgently take corrective actions!
Please let me know if you need anything else form me, if you want, I send you the files you need to test. Send me please a private email for that.
I'm now in trouble because I need to send he pcb to the designer in order to complete our project, and if tis is not solved quickly, we will all be out of time, that will have consequences we want to avoid.
Thank you.
MB
7 REPLIES 7
Message 2 of 8
panpan_fan
in reply to: mario.brizida
Hi @mario.brizida
I hope you are doing well!
Sorry to hear that you have this issue.
Please send your file to us. I will send you a private message for that.
Panpan Fan
Message 3 of 8
Hi @mario.brizida,
I haven't seen the files, but something that calls my attention in the images is that you appear to have very wide lines on the milling layer in the big cutouts. If you use 0 width lines for defining those cutouts does the render improve.
In general the recommended approach is to always use 0 width lines on the milling layer.
Let me know if you continue to run into problems.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
Message 4 of 8
yqliu
@mario.brizida , we did find a bug about hole generation recently and the fix will be included in the October update. It would be very helpful for us to confirm it's the same issue if you can share your pcb file to @panpan_fan
Message 5 of 8
yqliu
in reply to: yqliu
We confirmed that this is a different issue. Our development team is trying to give a fix for the next update.
Message 6 of 8
panpan_fan
Hi @mario.brizida
Thanks for your file!
I can reproduce this issue and have reported it to the develop team.
I will keep you updated when we release the fix for this issue.
Panpan Fan
Message 7 of 8
panpan_fan
Hi @mario.brizida
Today we release Fusion 360 V2.0.14567 and this issue should have been fixed.
Please update Fusion 360 and have a try, thanks!
Panpan Fan
Message 8 of 8
CGBenner
@mario.brizida Did the latest update fix the problem for you?
Chris Benner
Industry Community Manager – Design & Manufacturing
If a response answers your question, please use  ACCEPT SOLUTION  to assist other users later.
Also be generous with Likes!  Thank you and enjoy!
Become an Autodesk Fusion Insider
Inventor/Beta Feedback Project
