Fusion Electronics
Working an electronics project and need help with the schematic, the PCB, or making your components? Join the discussion as our community of electronic design specialists and industry experts provide you their insight and best practices.
Problems with milling layer
6 REPLIES 6
silvio3105
156 Views, 6 Replies
Why this Fusion does not recognize as hole?
Thanks!
Rectangle is milling layer
6 REPLIES 6
silvio3105
in reply to: silvio3105
Bump!
silvio3105
Little bump
jorge_garcia2
Hi @silvio3105,
I hope you're doing well. In this scenario what would be the expected result? I actually see the current behavior as better to any alternative I can think of. You would get some weird swiss cheese thing happening here.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
silvio3105
in reply to: jorge_garcia2
Screenshot from first post was made when I draw first PCB shape. That cutout where R1 is(down in the middle).
I had to edit DXF file which I used for PCB shape.
yqliu
@silvio3105 , the problem here is the milling area goes beyond the board region.
To edit the outline from imported dxf, the most convenient method is to import the dxf in sketch environment and there are many sketch tools you can use to modify it. Once you get the shape you want, you can create a 3D PCB and then push to 2D PCB to use the outline.
silvio3105
in reply to: yqliu
Yes, I fixed by importing DXF with right shape so I did not use milling layer.
I hope this bug will get fixed.
