Announcements
Problem FAO Overview
hello, I found myself with a problem during the 3D  of my PCB, the BUG silkscreen layer in a point cloud, I checked and tried all the possible parameters as well as a reinstallation, the problem also appeared on a other PC as soon as we generate or click on the CAM rendering parameters,
please help me Good day to you
Replies (7)
HelenChen-ElectronicsQA
Hi @Anonymous ,
Sorry to hear that you're having trouble.
Our development team had made a fix internally and we will keep you be posted when the fix is ready for you ASAP.
Sorry for any inconvienence.
Hope you have a great day too.
Helen
Helen Chen
Principle QA for Fusion 360 Electronics
Thank you to you and your team.
if that helps, it worked for 5 minutes right after logging in with another account, the silkscreen became readable, then after a while the problem reappeared
Hi Jack,
Thank you very much for your feedback.
We got similar feedback from other users like you about switch to another account will make it work a while.. 🙂
Helen
Helen Chen
The problem comes from the color of the background of the electronic diagram I do not see the link between the shema and the 3D rendering,
You just have to put the background back in white ..... How is it that when you put in black it bug the screen printing of the 3D view ....
Hi @Anonymous ,
Yeah, you are so smart! You found it!
By the way, we just was able to reproduce this issue and found the workaround to modify the color of board for black/white could solve the problem. Please see this update here: https://forums.autodesk.com/t5/fusion-360-electronics/cam-preview-snowy-since-last-small-fusion-update/m-p/10628537/highlight/true#M6985
Thank you very much for your sharing.
We will keep you be posted once this issue is fixed.
Helen
Helen Chen
