Fusion Electronics
Working an electronics project and need help with the schematic, the PCB, or making your components? Join the discussion as our community of electronic design specialists and industry experts provide you their insight and best practices.
Print-transparent-brd.ulp
2 REPLIES 2
FritsVuyk
173 Views, 2 Replies
Hi, coming from Eagle I  frequentualy used the print-transparent-brd.ulp.
https://github.com/drtrigon/eagle/blob/master/ulp/print-transparent-brd.ulp
This made very nice pictures of my pcb layout's.
I tried it in Fusion 360 but it doesn't do the job...
Anyone out here that can help  re-write  the ulp to make it working like it was in Eagle?
I don't have much knowledge of programming.
Thanks in advange
Fusion 360Fusion 360EagleEagle
Fusion360 vs Eagle
Tags (2)
2 REPLIES 2
FritsVuyk
in reply to: FritsVuyk
It's still horror to make readable assembly drawings in FUSION 360.
Why is there no help in fixing this !!!
jorge_garcia
Hello @FritsVuyk,
I hope you're doing well. That ULP isn't part of the default set, it was made by a user so it's not officially supported.
You could try reaching out to the original author to see if they will update the ULP. We are working on making assembly drawings a standard feature within Fusion but that is still a ways out.
One thing that could make things easier, in the CAM processor you can setup image export, if you configure the images to contain the specific layers you want on the assembly drawing.
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
Kudos are much appreciated if the information I have shared is helpful to you and/or others.
