Fusion Electronics
Working an electronics project and need help with the schematic, the PCB, or making your components? Join the discussion as our community of electronic design specialists and industry experts provide you their insight and best practices.
previous 3D pcb link to new pcb layout
3 REPLIES 3
anuradha.bodke
125 Views, 3 Replies
Hello Team,
I was design pcb layout and a 3d file added in the assembly,
now I want to change component placement of same pcb, doing so a new 3D pcb file was save
and again I have to add this file in assembly,
so that I want to know if I am doing various trial of pcb layout and 3D file of that is was single , it is possible
Please share if any suggestions
Thanks in advance
Anuradha
3 REPLIES 3
Hello @anuradha.bodke,
I hope you're doing well. I'm not entirely sure what you are trying to do. If you insert a 3D PCB into an assembly, you can use the Edit In Place (EIP) functionality to move components on the 3D PCB while still in the main assembly. That would allow you to make changes to the layout without having to save a brand new 3D PCB.
If I've misunderstood what you need (I'm sure I have) please reply with more information.
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
Hello Sir ,
I was design one pcb layout in fusion with 3D pcb file , then I save this for update in assembly,
ok this was a regular process of pcb design to assembly.
now I am design same pcb with different component placement with different electronic device in fusion.
so I have two different pcb layout with different electronic designs.
Now my question is that can I kept a single 3D pcb file for two different pcb layouts so that I will do many trial
versions of pcb without disturbing mechanical assembly, can this possible?
Thanks In advance
Anuradha
OK I understand what you are asking for. You could do this by constantly breaking the link between the 2D and 3D PCB. You would leave the 3D PCB alone in it's assembly and then from the 2D PCB editor break the link. Then in the 3D PCB you can link it to the new layout.
It's a manual process but it's possible.
Best Regards,
Jorge Garcia
