Fusion Electronics
Working an electronics project and need help with the schematic, the PCB, or making your components? Join the discussion as our community of electronic design specialists and industry experts provide you their insight and best practices.
Pour will not connect with pad
4 REPLIES 4
Stigoe
118 Views, 4 Replies
Hi, all.
My search didn't turn up any solution to my problem, so I'll try the brain trust of this forum... 🙂
I'm laying out a board with a Step-down DC/DC converter chip from TI (LMZ10501) where they have an example of a layout which I'm trying to reproduce, but I have a problem with the pads not being "flowed over" by a polygon pour.
Fig1 shows the example from the datasheet (it's upside-down to match my layout).
I've made a polygon pour for SGND and for the connection between VOUT and C3, but neither will fill properly, as can be seen in Fig2. They're named SGND and 3V3 respectively.
Anyone have a clue of how I can fix this?
Br,
Stig
4 REPLIES 4
silvio3105
in reply to: Stigoe
Pads are on top layer(red), but polygon is on bottom(blue).
Stigoe
in reply to: silvio3105
Hi, Silvio
Thanks for the answer, but, unfortunately, it's wrong.
You're correct that the pads are on the top layer and there is a pour on the bottom, but the pour for SGND and N$3 are both on the top layer. You can see the red dotted line for the pours, and the SGND pour is connected to the correct pads, but it only have a few blotches instead of filling it completely.
I've tried to adjust the values under DRC, but I haven't found a magic value to change.
jorge_garcia2
in reply to: Stigoe
Hi  @Stigoe ,
Check the width you have assigned to those polygons in Fusion 360. Make it the lowest number possible, I think you'll see it fill.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
Stigoe
in reply to: jorge_garcia2
Hi, Jorge.
Thanks! That helped, but I had to untick Thermals as well to get it to fill properly.
