Potentiometer SPICE simulation.
I am trying to simulate a circuit that employs two potentiometers but can't find a way to do it. I did find a similar issue on the Eagle forum (see https://forums.autodesk.com/t5/eagle-forum/eagle-8-5-2-potentiometer-simulation-does-not-work/m-p/77...), the solution there was to paste a text object into the schematic with pot parameters (see clipped txt below between hash marks)
.PARAM
val=1k
var=90
However, I can't even manage to paste any text into my schematic at all, is there a more user-friendly (and frankly obvious) way to achieve this? For example, EeasyEDA allows the user to adjust a percentage label directly on the schematic symbol.
Link copied
