Polygon connection to conductor route
benYNDLT
Observer Observer
benYNDLT
Observer
Observer
How can I connect a polygon pour to a routed wire (track)? Whenever I attempt to connect a track to a polygon an exclusion around the wire is created?
jorge_garcia
Hi @benYNDLT,
I hope this message finds you well. The key here is to make sure that the polygon, the trace, and the via have the same name. In Fusion 360, connections are defined based on net name.
So use the NAME command to rename these items and make sure they have the same name. Once you do this the polygon will connect to those items.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
benYNDLT
Observer
Observer
Yes! Perfect. I found the Name property in the wire properties. Works a treat.
Thanks very much.
