Fusion Electronics
Working an electronics project and need help with the schematic, the PCB, or making your components? Join the discussion as our community of electronic design specialists and industry experts provide you their insight and best practices.
Please help: Airwires breaking and reforming when component/part moved
3 REPLIES 3
s28039089
176 Views, 3 Replies
Whenever I move a component, the airwires linked to it break and reform with other components. All of my connections are messed up by this. Fusion doesn't say anything about the schematic and layout becoming unsynchronized (thus, ERC is not available). No forum responses have addressed it. How should I proceed? Spent about a week on this to no avail.
Here is a Screencast of it:
https://watch.screencastify.com/v/4NmvBxOKzPqNxc50LJCO
3 REPLIES 3
jorge_garcia2
in reply to: s28039089
Hi @s28039089,
I hope you're doing well. This is actually normal behavior, what happens here is that the airwires are always recalculating for the shortest length possible so when you move the IC some of the airwires (usually the power nets) will jump around to nearer gnd and power points.
If you run the ERC it will tell you that everything is consistent because none have been destroyed they just simply relocate to a nearer net member.
Let me know if that makes sense.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
s28039089
in reply to: jorge_garcia2
Hello Jorge,
Thank you for your response. Still a little confused. At 46:23 in this video (https://www.youtube.com/watch?v=zh03X5Wh5MM), the airwires do not reroute. Which setting is used to accomplish that?
Thank you so much.
Skip the intro 3:09 *** In this LiveStream, Brad will show the basics of creating a schematic and PCB layout in Fusion 360. He will be making a LED Runner, based off of the Velleman Kit MK107 Link to the outline: https://bit.ly/3bf3OWE ►FREE TRIAL | https://autode.sk/2uLm8a6 ►SUBSCRIBE | ...
jorge_garcia2
Hi @s28039089 ,
I hope you're doing well. The airwires will only move if the there's a shorter path available. In the example shown in the video, shorter paths didn't become available. So in other words, the airwires will switch only if a shorter path becomes available.
Hope this helps.
Best Regards,
Jorge Garcia
