placing "name" attribute on pcb, and adding offset for component names in modules
Manu_Roelants_Student
Message 1 of 1
Hey,
after a lot of work i finished my first big project with fuison 360 electronics.
Just one step remains. (re)placing all the names for my components. i delete these while doing the routing and layout.
mainly because when using modules in a schematic, the module name is used as a prefix for the component name.
I came across a forum post from eagle, where it was possible to select an "offset" option for the components name.
and it would reduce the name from "PSU_MAIN:R1" to something like "R101".
is this option also available in fusion? if have some really long module names sometimes.
also the only way i can add component names on the pcb is with the "autoposition attribute" command.
but this only works when i select the restore defaults option. when i only want to place the name, this does not work.
Any help or tips would appreciated.
Replies (0)
