Fusion Electronics
Working an electronics project and need help with the schematic, the PCB, or making your components? Join the discussion as our community of electronic design specialists and industry experts provide you their insight and best practices.
Placing a Wurth RJ45 connector from the library causes crash.
4 REPLIES 4
jroddisRT8HL
428 Views, 4 Replies
I'm trying to place a Wurth xxx-xxxxxxxx RJ45 connector on my board, from the built in library.
I can place the component on the schematic and PCB, but when I try to update the 3D view, Fusion crashes every time, giving an unhandled exception. I've submitted the crash report several times over the last few weeks as I have tried different things to place the component, such as placing in different designs, overhanging PCB/ not overhanging PCB, adjusting DRC etc but there's no real idea given feedback as to when this issue will be solved, or if it is something wrong with what I am doing.
Can anybody try to place the same component and see if it crashes their instance of Fusion, when updating the 3D PCB?
4 REPLIES 4
panpan_fan
in reply to: jroddisRT8HL
Hi @jroddisRT8HL
I hope you are doing well!
Thanks for reporting this issue to us.
Would you mind sending us your files for testing?
I will send my email address to you as a private message.
Thanks in advance!
Panpan Fan
panpan_fan
in reply to: panpan_fan
Hi @jroddisRT8HL
Thank for sharing your files to us.
The crash is a known issue and has been fixed in the internal build. I will keep you updated when we release it.
The root cause of this crash issue is that the device T1 is from Library ‘Wurth_Signal & Communications xxx’ which has a special char ‘&’ in its name.
The 3D PCB can’t deal with the char ‘&’ well. So Fusion crash when on 3D PCB.
As a workaround, I suggest you to delete Device T1 in the schematic.
And then rename the Library to remove the special char ‘&’.
Then Add the Device T1 back again from the renamed library.
Fusion 360 will not crash any more.
Sorry for the inconvenience. Before the fix release, please use the workaround to continue your work.
Panpan Fan
jroddisRT8HL
This works and now I can continue!
Thanks Panpan
panpan_fan
Hi @jroddisRT8HL
Today we release Fusion 360 V2.0.9849 and the crash issue should be fixed.
Please have a try, thanks!
Panpan Fan
