Fusion Electronics
Working an electronics project and need help with the schematic, the PCB, or making your components? Join the discussion as our community of electronic design specialists and industry experts provide you their insight and best practices.
PCB Thickness is incorrect based on the Eagle DRC Layer settings
0 REPLIES 0
Message 1 of 1
websterdav
88 Views, 0 Replies
the Fusion PCB Thickness is incorrect based on the Eagle DRC Layer settings.  I have followed the recommended workaround (setting it to 2-Layer and then back again to 8-Layer and Pushing again, and updating Fusion to the newest revision).  That did not work and the board is 5.534mm instead of the DRC thickness of 1.6mm.
The previous versions of the board worked fine (before May 2022).  The board DRC settings have not changed.
Does anyone know a fix?  Seems like some bug in a release that happened sometime in May 2022.
0 REPLIES 0
