Fusion Electronics
Working an electronics project and need help with the schematic, the PCB, or making your components? Join the discussion as our community of electronic design specialists and industry experts provide you their insight and best practices.
PCB Thickness in Fusion doesn't match Eagle DRC setting
7 REPLIES 7
Message 1 of 8
ogradyg
338 Views, 7 Replies
I have noticed that my 4 layer board, when pushed to Fusion has a thickness of 2.896mm while the DRC Layer stackup in Eagle shows a thickness of 1.5862.
Is there a fix or workaround for this issue?
Thanks.
7 REPLIES 7
Message 2 of 8
jorge_garcia2
in reply to: ogradyg
Hi @ogradyg,
I'll pass this along to our developers for review. I'll let you know what they say.
Best Regards,
Jorge Garcia
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
Message 3 of 8
CI7090
Hi, is the problem here resolved?
In my environment, the board thickness set in 2DPCB does not match the thickness measured in 3DPCB.
I am looking for a cause and a solution.
I am waiting for someone's reply.
I've posted it elsewhere and I'll share the link with you ....
https://forums.autodesk.com/t5/fusion-360-ri-ben-yu/3dnipusshushita-ji-banno-housanitsuite/td-p/1190...
Message 4 of 8
ogradyg
in reply to: CI7090
The issue is still present in my workflow and I haven't had any additional feedback from Autodesk.
I don't know if something similar happens for boards that originate in Fusion or if this is just happens when a board is pushed from Eagle.
Message 5 of 8
jorge_garcia2
Hi @ogradyg,
I hope you're doing well. In Fusion the thickness defined in the layer stack manager is respected. I'll report this, but using Fusion 360 will allow you to continue being productive and have the thickness respected.
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
Message 6 of 8
CI7090
@jorge_garcia2 @ogradyg
Thank you for your reply.
I will explain what I posted in the Japanese forum.
I was creating boards using only Fusion 360 without EAGLE.
The thickness was 1.67mm in "layer stack manager", but when I measured the thickness of the pushed 3D model, it was 1.705mm.
Is there a solution to this issue?
Message 7 of 8
jorge_garcia2
Hi @CI7090 ,
I'll follow up with our developers to see what's going on.
If you don't hear from me in a day or two feel free to bump the thread again.
Best Regards,
Jorge Garcia
Message 8 of 8
CI7090
@jorge_garcia2
Thanks for getting back to me.
I hope the problem will be resolved ...
