Announcements
pcb panel in fusion 360 Electronic
anuradha.bodke
anuradha.bodke
Hello Team
I  am using fusion 360 Electronic ,
Trial board file created & I want pcb panel how to do it in Fusion 360 Electronic
Please reply
Thanks In Advance
 Anuradha Bodke
jorge_garcia
Hello @anuradha.bodke,
I hope you're doing well. Panelization is not currently available in Fusion360 Electronics, there is some experimental development going on to make it happening but it has yet to bear fruit.
For now your best approach is going to be to try to panelize the 2D PCB following a similar procedure to EAGLE. Run the panelize ULP and then make as many copies of the board as you need.
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
