Fusion Electronics
Working an electronics project and need help with the schematic, the PCB, or making your components? Join the discussion as our community of electronic design specialists and industry experts provide you their insight and best practices.
PCB Mouse Bites or V-Grooves
1 REPLY 1
RCBakerBorn
147 Views, 1 Reply
Is there a way to create Mouse Bites or V-Grooves in Fusion 360.
I am trying to create breakaways for the board house.
I tried using holes of 0.015" spaced 0.03" apart but the program will not let me place them that close.
Then I need to create separation between the tooling rails and the actual copper portion of the PCB. I don't see that as a feature in Fusion 360.
Do these features exist in F360?
I could also create V-Grooves but I do not see how to do that in Fusion 360 either.
Please help.
Thank you.
1 REPLY 1
jorge_garcia2
in reply to: RCBakerBorn
Hi @RCBakerBorn,
I hope this message finds you well. There are no built-in automation for mouse bites or v-grooves but they are doable. V-grooves are the easiest all you have to do is use one of the user layers and draw the v-grooves. When you go to generate the gerbers export that layer as its own gerber file. Let the board house know that the info on that file is the v-grooves.
For mouse-bites you could use something like the attached ULP. It allows you to define a path and then it will place vias or drills along that path.
Let me know if you have any questions or concerns.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
