Fusion Electronics
Working an electronics project and need help with the schematic, the PCB, or making your components? Join the discussion as our community of electronic design specialists and industry experts provide you their insight and best practices.
PCB manual route
1 REPLY 1
jlnsantos72
99 Views, 1 Reply
PCB manual route
Dear members
I'm new on Fusion  (first time). I'm trying to finish a PCB drawing started on Eagle 8.6.  and  imported to Fusion. But when I try to draw a track that need to joint no another the track stops before joint and then on Eagle I used Move and solve this but on Fusion it did not work.
On same manner I try to put a socket from library but I cant put it right over  the end of a track and  it stays out (near).
I'm shure that's my problem, not Fusion issue but I realy need your help here.
Thank you.
1 REPLY 1
jlnsantos72
in reply to: jlnsantos72
Well I solve my issue by myself.
I found on bottom screen a small box with some options, the last one sign call my attention and I click there, so the first option was my solution: no restrictions to draw, position objects, etc. so I found now that I'm a abuser!
My only point is why an important feature is not more visible?
I understand that today no one (except some old guys, like me) wast this time and brain to draw a PCB, this and older versions do that, but I start draw PCB since 1974 with a edding 3000 marker pen, then glued strips on a transparent sheet to shoot a negative, etc.
