Fusion Electronics
Working an electronics project and need help with the schematic, the PCB, or making your components? Join the discussion as our community of electronic design specialists and industry experts provide you their insight and best practices.
PCB Export: Cylindrical Holes vs holes with a lot of faces
3 REPLIES 3
gmdouglas
182 Views, 3 Replies
HI all. I've exported a PCB from Eagle 9.6.1 to Fusion, and there's some inconsistent behavior with PCB holes in the Fusion body.
Even with copies of the same component/footprint, sometimes the holes for the component are normal, cylindrical holes, but sometimes they're structures composed of a lot of flat faces.
Why might this be happening? It makes joints referencing the center of some holes VERY difficult.
What can I do to prevent the face-type hole -- or what might I have done to make it happen for some and not others?
The attached screenshot shows 2 holes, both from the same Eagle footprint  ( 2 of the same components side by side).  I see this behavior with a number of components where some are normal holes and some are not.
Thanks for your help.
Labels (1)
3 REPLIES 3
jorge_garcia2
in reply to: gmdouglas
Hi @gmdouglas,
I hope you're doing well. I've pinged the developers on this.
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
gmdouglas
in reply to: jorge_garcia2
Thanks Jorge.  Let me know if the developers need to see the project.
jorge_garcia2
Hi @gmdouglas,
I hope you're doing well. The devs got back to me, it turns out this is a complex issue that occurs whenever fusion merges copper objects. They've made a few improvements but there's still more to do.
For now there is no workaround.
Best Regards,
Jorge Garcia
