Fusion Electronics
Working an electronics project and need help with the schematic, the PCB, or making your components? Join the discussion as our community of electronic design specialists and industry experts provide you their insight and best practices.
PCB Design Variants
1 REPLY 1
joao.ricardo.silva.97
217 Views, 1 Reply
PCB Design Variants
Hi everyone.
I wold like to know if there are any plans to a better Variant management.
It's a bit annoying to have to write a command each time you want to select another Variant. Eagle has a dropdown to select the current Variant.
A cool feature cold be a detachable window like new "Layers" window where you can select your current Variant.
Another thing is the Populate menu. Fusion should have a better way to select if a component is populated or not, and even if you want to populate/unpopulate a selection, you have to run a script...
Thank you
Tags (2)
1 REPLY 1
Hi @joao.ricardo.silva.97 ,
Thank you for this recommendation, I'll make a note of the feature request to strengthen the UI for the Variants command.
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
