Fusion Electronics
Working an electronics project and need help with the schematic, the PCB, or making your components? Join the discussion as our community of electronic design specialists and industry experts provide you their insight and best practices.
PCB Components appear as black flat boxes in 3D version
2 REPLIES 2
k.tsianaka
119 Views, 2 Replies
Hello! I am new in Fusion 360 and I have just import a Schematic and a Board File in Fusion from Eagle. The problem is, when I am pushing the 2D in 3D file, the components (a sensor and a connector) appear as black, flat boxes, without their true dimensions. Could you please help me to solve the problem? Thank you in advance!
2 REPLIES 2
jorge_garcia2
in reply to: k.tsianaka
Hi @k.tsianaka,
I hope you're doing well. Files from EAGLE may not bring the 3D package with it, so in that scenario you'll get the rectangles. If you want an accurate 3D model you'll have to copy the parts to a personal library and then assign 3D models to them. If you are in a rush, you can right click on a component and then select Add custom 3D model to quickly assign models one component at a time.
These videos cover the use of these workflows
https://www.youtube.com/watch?v=xNIEXCimRSg
https://youtu.be/pdBfKbTU8ew
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
k.tsianaka
in reply to: jorge_garcia2
Thank you very much for your answer! I am going to watch these videos and I hope to find a solution, thank you very much!
