Fusion Electronics
Working an electronics project and need help with the schematic, the PCB, or making your components? Join the discussion as our community of electronic design specialists and industry experts provide you their insight and best practices.
PCB 3D view changes
8 REPLIES 8
Message 1 of 9
rbkyorem
285 Views, 8 Replies
PCB 3D view changes
It has been a while since I used Fusion 360 electronics...
When I used it last time I could create fine looking canvases like this
But now whatever I tried soldermask is solid single green color where no mark of traces are showing up...
Can not create great looking render files with mechanics now it is annoying me...
I tried giving alpha values to soldermask in layer stack, I can see traces in their copper colors in 3D view  but then soldermask never gets rendered..
Is there something I am missing?
8 REPLIES 8
Message 2 of 9
Hi @rbkyorem ,
Sorry to hear that you're having trouble.
Do you mind sharing your board file to us for checking?
I will send private message you later.
Thanks a lot.
Best regards,
Helen
Helen Chen
Principle QA for Fusion 360 Electronics
Message 3 of 9
Hi @rbkyorem,
Thank you very much for your reply in private message.
After checking with our development team, we understood your issue and sorry for any inconvenience.
Before we have any update about this one, we'd suggest to try CAM Preview instead to change color.
Or not using View 3D PCB with fastest mode, but use recommended mode instead?
Is that OK for you?
Best regards,
Helen
Helen Chen
Message 4 of 9
Hello thanks for the reply,
I have tried this option too but with alpha level of 255 I can't see traces on board(Expected). If I set alpha level to 200 then I can see the traces but then when I render the board this is what I get.
Solder mask never gets rendered because of alpha value.
Below is what I want. From my older designs which still have the soldermask as canvas push. Notice that soldermask is rendered and traces are visible.
This removed feature really hurts my basic product presentation. It should be brought back.
Problem here is with new 3D view soldermask is not being rendered or  I am missing something in rendering configuration?
Message 5 of 9
Sorry...
At last I managed to get a canvas push. Without your reply I would never go and chose the fastest mode for 3D PCB view because naming is just wrong I think. I though fastest push would downgrade quality of my 3D view of PCB since I have RTX 4080 and i7 12700k ,I want the best quality view I can get.
Fastest push seems to solve my all problems thanks for the help.
My recommendation from this point would be to change fastest to canvas push maybe.
Topic solved.
Message 6 of 9
Hi @rbkyorem ,
Thank you very much for your feedback and good to know that you got the workaround.
As for renaming Fastest to Canvas Push, I will forward your suggestion to our team for review. Thanks a lot!
Hope you have a great day.
Best regards,
Helen
Helen Chen
Message 7 of 9
rbkyorem
in reply to: rbkyorem
I would like to add that without setting an alpha level I could not get fastest mode show traces on canvas today.
Message 8 of 9
Hi @rbkyorem ,
Understood. Thank you very much for your comment.
We will keep you be posted once we have any update about this.
Best regards,
Helen
Helen Chen
Message 9 of 9
Hi @rbkyorem ,
Hope all is well.
Good news that latest Fusion Production build 2.0.15775 is released today, which has an improvement about the issue you reported.
Could you please upgrade to latest version and have a try?
Hope it helps.
Best regards,
Helen
Helen Chen
