Fusion Electronics
Working an electronics project and need help with the schematic, the PCB, or making your components? Join the discussion as our community of electronic design specialists and industry experts provide you their insight and best practices.
Pads not connecting to route
1 REPLY 1
orlando.dc.sts
93 Views, 1 Reply
Hi!
I have a weird thing happening.
When I place this IC, it has these 'warnings' (I don't know what It's called).
And doesn't let me connect them to anything.
How/where can I fix this?
Thanks for the help in advance.
1 REPLY 1
Hi @orlando.dc.sts,
I hope you're doing well. You have a clearance error, go into the DRC clearances tab and make sure it's not set to too large a value. The other thing that could be going on here is if you have netclasses set, then those could be at play here.
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
