Fusion Electronics
Working an electronics project and need help with the schematic, the PCB, or making your components? Join the discussion as our community of electronic design specialists and industry experts provide you their insight and best practices.
Package rendered through the PCB board (B2B-XH-A)
0 REPLIES 0
Message 1 of 1
m.klemarczykautodesk
99 Views, 0 Replies
I use the part B2B-XH-A from standard Connector library from Fusion Libraries.
When I render the PCB in 3D view it shows the connector package inside the board instead of on top of it.
I use 2, 3 and 4 pin connectors in my project and only 2 pin B2B-XH-A has this issue.
Do I need to move it manually each time I push changes from PCB document?
Moreover, the drill is wrong for the pins, it is set to 25.19685 mil.
The pin is a square of edge 0.64 mm, which means that the radius is 0.64 times square root of 2.
Therefore, it will not fit the drilled via. According to documentation the drill should be 0.9 mm (which is 35.43 mil).
0 REPLIES 0
