Package Generator UI Issues
The latest changes to the package generator include some minor issues that make it annoying to use. These are all seen in the SOIC package.
First is that pressing tab does not cycle through the dimension fields, it just jumps back to the No. of Pins field then endlessly cycles between that and the "e" dimension. Tab used to work fine and made in much easier to punch in dimensions off a data sheet.
Second is that there seems to be a really short delay before the field accepts your entry as finished and auto populates the "in" value again. So if you pause to make sure you remembered a value correctly it inserts "in" and then when you continue typing it inserts after the units and gives an invalid entry.
