Fusion Electronics
Working an electronics project and need help with the schematic, the PCB, or making your components? Join the discussion as our community of electronic design specialists and industry experts provide you their insight and best practices.
Package generator confusion density level
2 REPLIES 2
jimUR4RG
175 Views, 2 Replies
Just a small thing but the Density level in the Package generator (specifically the SON generator, but maybe others as well) seems to be inverted.
When Density Level is set to Most, I would expect very small pads, so I can put many chips on my board (high density). However, the Higher the Density Level is set, the larger the pads become. This is a bit confusing.
Kind regards,
Jim
2 REPLIES 2
phaggren
in reply to: jimUR4RG
Hi Jim!
Those words is based on the IPC standard so they are same across the board with others EDA's and manufacturers.
I agree they are bit confusing.
Not the most scientific way to put it, but this is how I always think of it.
Least:      Takes the least amount of space (0402, BGA decoupling caps etc.)
Nominal: Takes the normal amount of space
Most:      Takes the most amount of space (easier hand soldering)
Cheers!
Petri
jimUR4RG
in reply to: phaggren
I didn't know that, thanks for the clarification!
