Fusion Electronics
Working an electronics project and need help with the schematic, the PCB, or making your components? Join the discussion as our community of electronic design specialists and industry experts provide you their insight and best practices.
Over-optimistic progress bars when pushing to 3D PCB.
1 REPLY 1
jesper8W75R
71 Views, 1 Reply
In another, and a lot more more miserable life, I used Windows.
I remember the progress bars from then, which would zoom to 99%  as if Windows were super fast.
Problem was that the last 1% would take 10 times as long as the time from 0-99.
It seems Autodesk is using the same brand of optimistic progress bars.
When pushing a 2D PCB to 3D, I often get this:
And, several minutes later, the 3D PCB will actually be rendered.
I think some code changes would be good here.
1 REPLY 1
yiqiu.han
in reply to: jesper8W75R
Hi, @jesper8W75R
In computer technology, The progress bar can only illustrate the progress of a process. The remaining time is always estimated, like download progress.
In 3D PCB computing, there're two stages. Stage1: Geometry computing, the progress bar in your screen capture illustrates the progress of it. Stage2: Graphics computing, Fusion is generating visible and operable model. So the remaining 1% you mentioned might be this stage.
I will bring this suggestion to development team to see if there's possibility to change the string used here.
Yiqiu
