Fusion Electronics
Working an electronics project and need help with the schematic, the PCB, or making your components? Join the discussion as our community of electronic design specialists and industry experts provide you their insight and best practices.
One hand doesn't know what the other is doing....
2 REPLIES 2
jesper8W75R
105 Views, 2 Replies
No, I'm not referring to support not knowing what's going on at development.
I am referring to the fact that INSPECTOR does not agree with the manufacturing preview and the actual state of my board.
See pic:
Board size is incorrect in INSPECTOR.
Also, the number of pads is incorrect.
Sent to support, Case number 19010939
2 REPLIES 2
panpan_fan
in reply to: jesper8W75R
Hi @jesper8W75R
I hope you are doing well!
The Dimension value in the inspector is not the 'CAM board size'.
It shows the size of the whole board. You can drag any part out of the board and then check the value in Inspector.
Another issue for the pads number. You may miss the PTH pad in the CAM dialog. Please expand the Drills to check the PTH number. The number of smd pads and PTH pads should equal the value in Inspector.
Hope it can help!
Panpan Fan
jesper8W75R
@panpan_fan
I already figured this out and reported back to support, who then closed the case, despite these issues.
No, it does not show the size of the whole "board". It shows the size of ANY polygon edge you might have dragged out over the dimension edge. Something that basically everyone does, to make GND fill on the boards top and bottom layer.
That size is TOTALLY IRRELEVANT for anything. It's the size of nothing, as there IS no board there.
And yes, the Inspector calculates SMD pads PLUS THT pads, whereas the CAM preview calculates these as two different thing.
WHY do you have to make everything so unbelievable inconsistent and confusing?
Again, and excuse/explanation from you to cover up the weird thinking in the design.
I consider this a bug, or, at least in best case, an extremely bad user interface / lead text.
