Fusion Electronics
Working an electronics project and need help with the schematic, the PCB, or making your components? Join the discussion as our community of electronic design specialists and industry experts provide you their insight and best practices.
Now what am I doing wrong; Polygon pour is not filling the polygons
1 REPLY 1
m_walczak
624 Views, 1 Reply
I am trying to do a few polygon pours for a small switching regulator per it's datasheet.  I have done this same operation in Eagle with no problems, but with Fusion it is not happy.  I am attaching a screen grab so people can see what is happening I have one pour that worked, and that is by L1. The only issue here is that the pour has a radius and I really don't want that.  Now id did the same thing with C3 and C4, but as you can see it did not fill. I did try it with and without orphans enabled with no luck.
1 REPLY 1
m_walczak
in reply to: m_walczak
I have this resolved. I had to turn off thermals and reduce the width to fill and to square up the corners.  Calling "width" makes no sense, I would think "corner radius" would be more explanatory.
