Fusion Electronics
Working an electronics project and need help with the schematic, the PCB, or making your components? Join the discussion as our community of electronic design specialists and industry experts provide you their insight and best practices.
No "GO" button anymore!
2 REPLIES 2
Tbaker25
101 Views, 2 Replies
Autorouter- when selecting aiwires to route, you cannot select "GO" to continue routing! This is a pretty big problem. It was always there in Eagle, but the traffic light icon is completely gone! How can I route only a select set of signals without naming all of them in the command line?
Tom
2 REPLIES 2
jorge_garcia2
in reply to: Tbaker25
Hi @Tbaker25 ,
I hope you're doing well. The key here is to press enter twice once you have selected your airwires. That will do the same as the GO button.
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
Tbaker25
in reply to: jorge_garcia2
Thank you for the workaround. Definitely needs a UI fix on this one. 🙂
Tom
