Fusion Electronics
Working an electronics project and need help with the schematic, the PCB, or making your components? Join the discussion as our community of electronic design specialists and industry experts provide you their insight and best practices.
No permission to edit??
4 REPLIES 4
jesper8W75R
151 Views, 4 Replies
Why can I not edit my own 3D models?
4 REPLIES 4
AlinaPeng
in reply to: jesper8W75R
Hi @jesper8W75R
I'm very sorry to hear that you're having trouble.
The popup means you were editing a package that stored in a Fusion team hub in which you don't have access to.
There're many cases would give such popup when editing package. e.g.
1. Editing a public package which stored in fusion team, since you have no access it would give such popup
2. Two users work as collaborator. User A create a package in Fusion and create managed library to a managed folder in which the two users both have access to. User B use the managed library in Fusion then edit the package which store in User A's team hub but he don't have permission to the User A's team hub, then it would give same popup.
If they're not the case, would you mind invite me to your team hub so that i could take a look?
Best Regards,
Alina
Alina Peng
SQA Engineer
jesper8W75R
in reply to: AlinaPeng
@AlinaPeng
I don't use public libraries.
And I have totally disconnected from managed libraries as it just doesn't work and are incredibly slow.
It was, afaik, my library and MY own 3D model, which I had added.
I should have added more information as to what happened, as I cannot even remember myself.
I have posted umpteen bug reports and posts about various issues the last few days, so it is becoming a blur.
I will try see if I can recreate the issue.
jesper8W75R
Found the issue and can recreate it.
But how do I invite you to my Team HUB? I need an email address.
AlinaPeng
Hi @jesper8W75R
I sent private message to you, please check the message then invite me to your hub and let me know the library you have issue. If you can recreate this issue, it would be great to share with me the video.
Much appreciate for your reports and help!
Alina
Alina Peng
SQA Engineer
