Fusion Electronics
Working an electronics project and need help with the schematic, the PCB, or making your components? Join the discussion as our community of electronic design specialists and industry experts provide you their insight and best practices.
New fusion user looking for help
2 REPLIES 2
79 Views, 2 Replies
I have 2 problems I'm hoping someone could help me with.
Firstly my model wont all turn a solid colour only the side panel will? I have no clue how to get the rest to look like a solid piece.
secondly, I need to add a pcb board and battery to the inside of the device, any advice on how and where to do that would be great.
2 REPLIES 2
RichardHammerl
in reply to: 20725361
Hi @20725361 ,
i don't know a solution to the mechnical design problem, but I can help in inserting a PCB into your design.
This is quite simple. Open your mechanical design and select the PCB or 3D model you would like to insert in Fusion's data panel with a right mouse click and chose "insert into current design".
I hope this helps. Regards,
Richard Hammerl
TrippyLighting
I've looked at yur design andwould assume that you have forgone going through the educational mateirlas available here:
I would complete one of the introductory courses to get a better understanding of how Fusion works.
To create better and more functional designs it helps to understand the difference between bodies and components and then perhaps a look at Fusion Rule #0 followed by a look at Fusion R.U.L.E #1 & 2 would provide some guidance.
Peter Doering
