Fusion Electronics
Working an electronics project and need help with the schematic, the PCB, or making your components? Join the discussion as our community of electronic design specialists and industry experts provide you their insight and best practices.
need help with PCB Design
1 REPLY 1
supraman2jz
66 Views, 1 Reply
Hi everyone,
I am trying to design a harness adapter that will take the factory connector for my car and change it to a more standard connector. The PCB is very simple and only needs pads and traces to be connected to one another. the issue is I have never used the electronics design side of fusion 360 so I have no idea what I am doing. any help on this would be appreciated. here is a fusion model I whipped up showing what I am looking for but in a gerber file as well as a real one that exists but is different from the one I designed.
1 REPLY 1
supraman2jz
in reply to: supraman2jz
here is an additional file, in this one I drew lines representing how I think the traces should go. not all of the pins on the yellow connector are used and this ends up leaving pins on both connectors un used but I THINK this routing is the optimal one with the pins I actually need.
