Fusion Electronics
Working an electronics project and need help with the schematic, the PCB, or making your components? Join the discussion as our community of electronic design specialists and industry experts provide you their insight and best practices.
NC Drill File In not Clearly Open At manufacturing House
4 REPLIES 4
yuvraj_wadye
131 Views, 4 Replies
Hello Autodesk,
I Have Serious Issue,
I have Generated Gerber data and NC drill file for my PCB Manufacturing but after giving data to the manufacturer he is saying that NC drill file is not showing correct data or not loading even after changing its format and extension.
We checked the gerber and drill file on our  viewer software and its looks correct.
Please tell me what we do to solve  NC Drill Problem .
4 REPLIES 4
Hi @yuvraj_wadye,
I hope you are doing well. Did you let the board house know the exact format of your Excellon drill file?
If everything looks correct in your gerber viewer, then a legitimate board manufacturer should not have any problems with the file. Who is the board manufacturer?
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
He is our regular manufacturer he even printed our many 4 layers boards.Even I created drill chart from your given ulp,but its not useful because from that drill chart exact drill size is not showed and we cant able to get drill chart in gerber format ,its export in pdf format.
Hi @yuvraj_wadye,
OK thank you for that insight. Would you be willing to share the manufacturing files for review? If you are I'll DM you my email and I can take a look.
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
After a many efforts we have created one drill chart file in gerber format and we given it to our manufacturer .
Let see what happen after fabrication if everything goes as per our expectation then its ok If not then I will Share Files and you check that.
At least I am satisfied with fusion team quick response , Just have to add features like other Pcb design softwares and unexpected errors handling .
I hope one day fusion will become best design software in all aspects.
By the way Thank You For your response !!
Good Day Or Night !!
Yuvraj W.
