Multiple net names for same pin?
shaische222
shaische222
I'm trying to map multiple nets to the same pin like I see was done in the attached schematic using some other program. Is this possible? If so, how?
shaische222
Anyone?
jorge_garcia
Hi @shaische222,
I hope you're doing well. This is not possible in Fusion Electronics, Fusion requires net names to be unique and you can't have too differently named nets connected.
You can work around this by using 0 ohm jumpers (basically components that are shorts internally). From the point of view of the schematic you would be connecting different nets to 2 sides of a components so the netlist is happy but internally those nets are shorted so you achieve the desired effect.
Please consider if you really need to do this, connecting differently named nets can lead to confusion and even though other tools allow it, it's a dangerous approach.
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
