Moving the Name on a Pin in Library Editor
It appears that it's not currently possible to move the name of a pin in the library editor. This makes it really difficult to design symbols such as a quad package op-amp because the drawings intersect the names. See here for an example: https://forums.autodesk.com/t5/eagle-forum/move-pin-name-text-in-symbol-editor/m-p/9409182/highlight...
Is the only solution to this right now to hide the name and add text manually? This seems like it could be very error prone and also time consuming.
jorge_garcia
Hi @Anonymous ,
I hope you're doing well. For now this is the best way to proceed if you need the text to be arranged in some other arrangement.
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
rick.kilcoin
Observer
Observer
Are there plans to address this issue in Fusion 360 Electronics?  It would be nice to be able to re-orient pin names in the symbol without having to use the work-around in the previous post.
meetSU9F2
Observer
Observer
Honestly, this is such a basic feature, I cannot believe this has not been addressed yet. It has been 3.5 years since the question was first asked.
jorge_garcia
Hi @meetSU9F2,
To be honest it's probably been 20+ years since this question was first asked. At first look, it seems like how could we not have this? In practice, it's not a show stopper, as the 1000+ of designs made in EAGLE can attest. Following recommended library conventions, it doesn't get in the way and it's one less thing to worry about.
With that said, there are plans to revisit the library authoring experience and do an overhaul. I'll report this to our product management team.
UPDATE: Just looked and this seems like it will be addressed soon
Best Regards,
Jorge Garcia
