Fusion Electronics
Working an electronics project and need help with the schematic, the PCB, or making your components? Join the discussion as our community of electronic design specialists and industry experts provide you their insight and best practices.
Move multiple components?
8 REPLIES 8
Message 1 of 9
infinitemach
1143 Views, 8 Replies
I need to move multiple components at a time. It appears as if you can only move a single component at a time. If I select multiple parts then try to move them it only moves the part that had its move handle clicked.
It seems like moving multiple parts would be basic functionality.
Is there something I'm missing here?
8 REPLIES 8
Message 2 of 9
mtl.asm
in reply to: infinitemach
use select to highlight the components you want to move
then select move
then right click in the pcb design space
a menu box will appear with an option "move group"
after selecting move group, then all the items in the group will move with the mouse cursor.
Message 3 of 9
infinitemach
Thanks, that does work. I still find the process for moving multiple parts very unintuitive. I would expect to just select multiple parts and then move them, without having to select another menu.
Message 4 of 9
jeff_strater
what do you mean by "Move" here:  "I would expect to just select multiple parts and then move them, without having to select another menu".  Do you mean drag?  As in, drag a component using the left mouse button?  If so, you are correct, drag is only applicable to a single component.
Jeff Strater
Engineering Director
Message 5 of 9
infinitemach
in reply to: jeff_strater
"Move" would be drag, then. IMHO selecting a group of objects, no matter what the design software, then left-click over one of the objects, then moving the mouse would move/drag the group. This is rather standard behavior in other software.
Message 6 of 9
mtl.asm
is this a serious post?
Message 7 of 9
Hi @infinitemach,
So just to clarify, within Fusion 360 if you form a selection then left click hold and drag one of the members of the selection then the whole group will drag. It sounds like this is not what you are seeing. Can you confirm if this works for you?
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
Message 8 of 9
Yes, it is working as expected. My problem was that I was not left clicking on the selection handle of a selected part. Once I did that it worked.
Message 9 of 9
jeff_strater
I apologize, @infinitemach - I did not see that this was in the Electronics forum - I was answering the question in regards to the Design workspace in Fusion.  I am not familiar with the Electronics workspace.  Please disregard my answer.
Jeff Strater
