Fusion Electronics
Working an electronics project and need help with the schematic, the PCB, or making your components? Join the discussion as our community of electronic design specialists and industry experts provide you their insight and best practices.
Move componenet PCB if the board is already wired
1 REPLY 1
simonJXDTS
65 Views, 1 Reply
Hi all,
I've made a baord, but I've to replace one component on my board ESP32-WROMD to ESP32-WROME. I've made the changes in schematic but on the pcb I can't move my new esp32 on my board because I think I've already have all my wire trace.
Here is a capture
Is is possible to move my component without erase all trace ?
1 REPLY 1
jorge_garcia2
in reply to: simonJXDTS
Hi @simonJXDTS,
I hope you're doing well. If you just want to place it you can set the violators mode to "Ignore violators" and that will let you place the part despite all the violations you are going to run into. Once you place it you will likely have to clean up some of the routing anyway. You can find the violator settings in the right most icon on the toolbar that's at the bottom center of the canvas.
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
